Windows 10 Vectorworks causes no text only icons for explorer folder and all programs
MartinFahrer
Before blaming anything else, I opened, saved, ran and exported all other programs on my PC including Sketchup, Ai, PS and some others. Nothing happened but ewhen I do the following in V works text on screen disapears
Open Vectorworks/
open Vectorworks file/
Export DWG/
The save bar goes funky and I can't see text in explorer.  I will attach photos of occurrence this evening can't do a screen capture.
Yes I turned it on and back off again, yes I uninstralled and reinstalled vectorworks.
Attached are machine specs
8 answers to this question
On 5/27/2022 at 8:45 PM, jeff prince said:
This is a very common Windows problem.  My wife's computer exhibited this when I taxed the poor devil too much.
 Except this is a brand new problem and I have been using Vectorworks on this computer for a while.  My computer is not being "Taxed" that is for sure, not with the processor etc I have on board.
You installed a new video card driver about a month ago according to the images you posted...
This behavior is a well know windows problem...
Yes but this didn't start a month ago, but two days ago and Vectorworks is a daily used program.
UPDATE:
@JuanP
Still no solution found.  It is a consistent repeatable error.  I have found out it is only when exporting a sheet layers or multiple sheet layer.  I export too the design layer to DWG works fine.  I also exported as several different file types with out a problem including EPSF and PDF etc.
I am pretty sure that it's not a graphic display driver.
After uninstalling and reinstalling, as well as downgrading the video driver to the same results.  I used DDU to delete all of my video drivers at go back to "Microsoft basic driver" Still the same results.
Open Vectorworks/
Export DWG as a sheet/.
I also Opened my older copy of Vectorworks 2021. and no issues exporting at all.
That trouble shooting I'm sure it's a Vectorworks 2022 problem.  I did uninstall and reinstall Vectorworks, importing all my custom settings.  Going to try and do a clean intall with out my settings and see if that works.
