How to Dimensions
Hi, I can't find anything on adding dimension points along an overall dimension. i.e width of walls intersecting that walls overall dimension. I see you can right click and some times you get the "add dimension" but that only works for one point. How do I keep adding many in the one operation?
If you have a single Dimension created in Linear Mode then like you said, right-click on it + select 'Add Dimension(s)' from the context menu + then it effectively becomes a Chain Mode Dimension after the fact + you can add as many extra dimensions as you like
Ok, but when you "add dimension" you can only do one point at a time, then right click for another, is that right or is there a way to invoke the chain dimension right from the start?
Is there a way to have a shortcut for the tab key on a mac as being left handed the tab key is annoying?
No that's not right. You should be able, once 'Add Dimension(s)' has been activated, to keep clicking to your heart's content + add as many extra dimensions as you like. I have no idea why this isn't working for you but someone else might
  • 1 year later...
