Ever since I upgraded to SP5 (curiously reflected as "SP3.1" when I boot VW) I can't import more than one PDF. A second PDF causes a death-spiral beachball and requires a force quit. Coincidental to this problem is the inability to close a VW file by clicking the red circle at the top, left side the window. This, of course, is added to the problem of not being able to switch between multiple open files by clicking on the window tab. It only switches via the "Window" pull down menu. These and other bugs are annoying, but not totally fatal, but this PDF problem is BIG. I often import PDFs and VW's failure to do this anymore is a big pain. I have to change a file to some bitmap format to bring it in and you can't snap to a JPEG. I need vector file import. Is anyone else seeing this and, if so, have any idea how to fix it?
MHBrown
Thanks,
MHBrown
9 answers to this question
