giannidowns Posted May 19, 2022 Share Posted May 19, 2022 Hi all, anyone know where I can find the properties of this particular part of a curtain wall? I'm able to change the texture/properties of all elements except this piece at the tops and bottoms. Any help would be appreciated. Quote Link to comment
Tom W. Posted May 19, 2022 Share Posted May 19, 2022 In the Frame Settings dialog, in the 'Top Boundary Frames' + 'Bottom Boundary Frames' panes, check the attributes you have set for for the Caps. Quote Link to comment
TomKen Posted May 19, 2022 Share Posted May 19, 2022 (edited) Select the curtain wall edit tool, then select the frame or frame pieces. Right click and select edit frame. You can change the material 3 ways, change the class it is assigned to, select a different material in the use material option of change the texture in the texture box. Edited May 19, 2022 by TomKen Quote Link to comment
giannidowns Posted May 19, 2022 Author Share Posted May 19, 2022 Thanks @TomKen and @Tom W., I missed the Cap textures in my editing. I appreciate you both answering so quickly! Quote Link to comment
