Ed Dunn Posted March 16, 2006 Share Posted March 16, 2006 I am trying to produce a fan symbol out of the incandescent light tool. I can type an "F" into the Config Label field but it winds up outside the circle. When I enter a zero in the x and/or y field (default = 1") and press enter, the field changes to a -36' or some other similar figure and the "F" winds up off the sheet. VWA 11 did this jut fine. Quote Link to comment
msclark Posted March 17, 2006 Share Posted March 17, 2006 There is a fan symbol in HVAC_Equipment in the resource browser, see if it will work for you. Quote Link to comment
Ed Dunn Posted March 17, 2006 Author Share Posted March 17, 2006 Thanks for that. I will use that symbol for now but I think it would still be a good idea if the problem were fixed so that the fields worked as designed. Quote Link to comment
