I randomly starting getting a strange occurrence with dimensioning. We've been using the standard Arch dim style in our drawings with either the 10pt or 12pt dim text style. Recently I tried adding additional dimensions to multiple drawings and the dimensions drawings are huge compared to what's in there even though it's the same dim style and I was sure to put my text style to what was already in the drawing. If I create a custom dim style, it works fine and draws the dimension with the correct text size, but if I use the arch dim style, and no matter what I do with different settings, it draws the text very large. This happens in all files I've tried to add additional dimensions in. I've attached screenshot showing size difference in text. I usually dimension in annotation space, but I've tried in both design layer and annotation on multiple drawings with the same result of large text.
If anyone has any ideas on settings or other possible solutions, it would be appreciated.
LukasC
Hello all,
Thanks,
Lukas
5 answers to this question
