Yegaer Posted May 17 Share Posted May 17 Hi All, new to Vector works, I have a bunch on Sceptron fixtures on truss uprights and for the render i want the diffsued light source to glow, i can activate the beam of the light but i need it to glow like a neon tube, is there an easy way to make this happen?? Quote Link to comment
Kevin Allen Posted May 17 Share Posted May 17 I have not tried this, but if you can make the lens a lens object you can set the lens to pick up the color from the color filed in the OIP through the Document Spotlight preference. You need to have a class for the lens and a glow texture that uses the object attribute. Quote Link to comment
Yegaer Posted May 18 Author Share Posted May 18 Thanks Kevin, Sounds tricky as I'm new to Spotlight, The Fixture is an object so i will have to edit that and isolate the lens part and assign the glow texture correct? Can you do a bullet step by step for me by any chance? 🙂 Thanks Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted May 19 Vectorworks, Inc Employee Share Posted May 19 Here's a spotlight lighting device rendering cheat sheet that covers the workflow. It was created a while ago so some of the Dialogues have been updated a bit since but it should still be good Spotlight Rendering Cheat Sheet.pdf Quote Link to comment
