evogroup Posted May 16, 2022 Share Posted May 16, 2022 I'm running VW 2022 on a Mac OS 12.2 and can't Import or Export DXF/DWG. Nothing happens at all, no dialog box or file menu pops up. All other files type import/export fine. Any ideas? Quote Link to comment
Steven Kenzer Posted May 17, 2022 Share Posted May 17, 2022 I would update to 12.3.1, the most recent OS update, and see if that helps.. Quote Link to comment
evogroup Posted May 18, 2022 Author Share Posted May 18, 2022 On 5/17/2022 at 8:00 AM, Steven Kenzer said: I would update to 12.3.1, the most recent OS update, and see if that helps.. I just updated to 12.4, still won't import or export. Quote Link to comment
Administrator JuanP Posted May 18, 2022 Administrator Share Posted May 18, 2022 @evogroup What application is this file coming from, and what version? Also, can you send us the file for testing? Quote Link to comment
evogroup Posted May 18, 2022 Author Share Posted May 18, 2022 52 minutes ago, JuanP said: @evogroup What application is this file coming from, and what version? Also, can you send us the file for testing? Vectorworks won't even bring up a file menu to select a DXF to import, nothing happens. It won't export a file as DXF either. Other file formats work as expected. Quote Link to comment
