Casey Clark Posted May 13, 2022 Share Posted May 13, 2022 Anyone have an issue with 2 partially overlapping label legends? New this year, when I insert a fixture symbol, I get 2 dialog boxes asking if I want to replace, merge or keep parameters. It does not matter which I choose, I get double legends. I though it might be an artifact in the drawing, but it happens when inserting a light that had not previously been used. I went looking for a way to delete or un-assign a label legend, but can't find one. Quote Link to comment
markdd Posted May 13, 2022 Share Posted May 13, 2022 The record alert that you are seeing is because you are importing a record which has the same name as one that is in the drawing already but is different. This alert should have nothing to do with Label Legends. Can you post an image of the problem you are having as you may not be using quite the right terminology? Quote Link to comment
Casey Clark Posted May 13, 2022 Author Share Posted May 13, 2022 I can this evening. My VW is on a machine in my home office. Quote Link to comment
Casey Clark Posted May 18, 2022 Author Share Posted May 18, 2022 Here is an example. Quote Link to comment
markdd Posted May 18, 2022 Share Posted May 18, 2022 Can you post the lighting device in a clean file as the image doesn't really help. Quote Link to comment
Gonda Posted September 17 Share Posted September 17 Did you ever get to the bottom of this problem? Cheers Quote Link to comment
Vectorworks, Inc Employee klinzey Posted September 18 Vectorworks, Inc Employee Share Posted September 18 It's likely that there is a label legend applied to the light and the accessory. Select the accessory in the OIP and change the label legend to None. 1 Quote Link to comment
