Scott Schwartz, AIA Posted May 11, 2022 Share Posted May 11, 2022 Not much out there for specifics on this at all. 3 hours searching everywhere and nothing addresses my questions below. Brain is fried on this topic. Working on Building Exterior Elevations, notations in a Sheet VP. How do I save my custom preferences for the tools? Scale Factors, Text Style, etc. How do I set the Reference Elevation to my own selection? How do I set a Control Point to my own selection? I'm sure it's all right in front of me somewhere but I'm not seeing it. This is nothing like Revit's "intelligent" elevation markers. But I am here using VW now for many reasons... Thanks. Quote Link to comment
Scott Schwartz, AIA Posted May 13, 2022 Author Share Posted May 13, 2022 Guess this hasn't come up before with any other Architect? Anyone? Quote Link to comment
willofmaine Posted May 14, 2022 Share Posted May 14, 2022 Benchmark elevation in a sheet viewport: for Elevation Display (in the OIP), select "Y value relative to reference elevation". You can then set the Reference Elevation to whatever you like. For example, if the First Floor of your building is 216', set the Reference Elevation to -216'. (This assumes your First Floor is at Vectorworks' Z=0, which I highly recommend: if you need to change the vertical elevation of your building, move the World, not your building/model). When creating the Elevation Benchmark, you can click on the Wrench/Pencil icon at the top to set the Reference Elevation and other settings for future creation. That Wrench/Pencil icon applies to other tools as well, and may address some of your other questions. Not sure what a "Control Point" is (at least as a VW tool)... Quote Link to comment
StefanoT Posted May 14, 2022 Share Posted May 14, 2022 (edited) Hopefully this tool will be soon replaced/updated… https://www.vectorworks.net/en-US/public-roadmap Edited May 14, 2022 by str Quote Link to comment
Scott Schwartz, AIA Posted May 14, 2022 Author Share Posted May 14, 2022 (edited) @willofmaine Thanks for the reply. Figured out the reference setting adjustment. Not intuitive at all. Also, got it on the preferences with the Wrench rather than than OIP for Scale. The text style is not in that dialog though but figured out how to select text menu mid-insertion. Not intuitive either. One would think you could easily set all properties of an object in the OIP, then check a box "set as default". Even my $600 Bluebeam can do that. Edited May 14, 2022 by Scott Schwartz, AIA Quote Link to comment
shorter Posted May 19, 2022 Share Posted May 19, 2022 create a symbol of a benchmark tool correctly set up and store the symbol in your office workgroup folder Favorites. set the symbol to place as plugin object. Quote Link to comment
Pieter-Jan Vermeire Posted July 7, 2022 Share Posted July 7, 2022 On 5/19/2022 at 8:10 AM, shorter said: create a symbol of a benchmark tool correctly set up and store the symbol in your office workgroup folder Favorites. set the symbol to place as plugin object. Thanks for the tip. My only problem now is that the tool is scale sensitive. Did you create a red symbol for each scale you use? Quote Link to comment
Guest Wes Gardner Posted July 11, 2022 Share Posted July 11, 2022 Hi All, For me, the quickest way is to use good old symbol technology and a story pole...I just get into Annotation Space of a section (or Elevation) and create my benchmarks either using the "Y" setting or just drawing lines, circles and text. I then create a symbol and can place my story pole very quickly in subsequent views - very quick, very efficient -and if a change needs to be made, change it at the symbol level...done. Wes Quote Link to comment
