twk Posted May 9, 2022 Share Posted May 9, 2022 Does anyone know which function calls to use for setting record fields to be controlled by the data manager field mapping. Have just setup a data mapping for a particular record to WinDoor objects, and they seem to work -- manually, however I have the records already attached to some odd 200 objects. Have tried vs.SetParamStyleType, put that seems to be only for plugin objects, not records. Any help, or pointers in the right direction would be greatly appreciated. Cheers, Tui Quote Link to comment
Pat Stanford Posted May 9, 2022 Share Posted May 9, 2022 Check out the Data Sheet functions and see if they do what you need. DSH_GetDSFieldValue. Gets Object's Data Sheet field value, operation status(disabled/enabled/invisible/black/red), value source type (not set/from instance/from mapping). 1 Quote Link to comment
twk Posted May 10, 2022 Author Share Posted May 10, 2022 Thanks Pat, those seem to be calls for fields on the datasheet for the object, not the actual custom record. Quote Link to comment
