gvictoria1 Posted May 9, 2022 Share Posted May 9, 2022 When I zoom in and out on sheet layers I get some very annoying vector trails which are the full image from the viewport crop - it's pretty annoying when I'm showing my work to someone else - is there any way to turn this off? thanks Quote Link to comment
Pat Stanford Posted May 9, 2022 Share Posted May 9, 2022 OS Version, Vectorworks Version, Hardware you are running on please. Best to click on your user name at the upper right and then on Account Settings. Click on Signature on the left and put that information there. Makes helping you much easier. Quote Link to comment
gvictoria1 Posted May 9, 2022 Author Share Posted May 9, 2022 Here's the info - 🙂 and a screen shot showing an example of what I see when I zoom in and out thanks - Vectorworks 2021 Mac OS Big Sur 11.6.2 2.4 GHz 8-Core Intel Core i9 AMD Radeon Pro 5500M 8 GB Intel UHD Graphics 630 1536 MB Quote Link to comment
Pat Stanford Posted May 9, 2022 Share Posted May 9, 2022 Hardware and software versions look ok. Make sure that VW is set to use the Radeon card. Consider turning off Automatic Graphics Switching in System Preferences. There are separate options for Battery and Power Adapter. If that is not it, can you post or DM me the file to make a closer look at? Quote Link to comment
M5d Posted May 9, 2022 Share Posted May 9, 2022 Also, try changing your Navigation Graphics setting. I encountered the same, or similar, in 2021. 1 Quote Link to comment
gvictoria1 Posted May 9, 2022 Author Share Posted May 9, 2022 Switched both the display preferences (my gut tells me this may have been the cause) and the Mac preference for the battery use solved - thank you 2 Quote Link to comment
