Elite Exhibits Posted May 8, 2022 Share Posted May 8, 2022 Mac OS 11.6.5 - Mac Book Pro - VW Designer 2022 You should be able to right-click on an item in the Resource Palette an pull down to the Edit option. This is traditionally what has worked. VW 2022 - one now is required to click once to select the desired item, then right click to get the Edit option for the desired item. ¿ Extra step now required ? Suggestions ? Peter Wrong Resource Selected.mov Quote Link to comment
0 Pat Stanford Posted May 8, 2022 Share Posted May 8, 2022 I am not seeing this behavior in my install of VW2022 SP3. I also don't remember anyone else mentioning this bug before. If you don't have SP3, please install that and see if the problem repeats. If you have SP3 and still see the problem, please create a simple test file with just a few symbols and see if you can repeat the problem. I would like to figure out if it is a VW problem or a document problem. Quote Link to comment
0 Elite Exhibits Posted May 23, 2022 Author Share Posted May 23, 2022 Pat Updated VW Still happens ... Right clicking to edit or to apply I use the track pad on the MacBook Pro and left hand on the keyboard. The video shows that, unless I click the resource first, then right click to edit, it edits what ever was selected (Often out of view). This is aggravating as I almost always apply / edit textures with a right click inside the Resource Browser. ¿ Something is not set right ? Same drawing method dating back to (even before ?) VW 2013 Mac OS 11.6.5 - MacBook Pro - VW Designer 2022 Suggestions ? Peter ************************************************** Resource Select Error.mov Quote Link to comment
0 Pat Stanford Posted May 24, 2022 Share Posted May 24, 2022 What happens if you hold down the Control Key and click rather than right clicking? Control-Click was the way to get to the menus on single button apple mice for a long time. And I am still not seeing what you are saying even when I use the trackpad. Have you checked the trackpad settings in System Preferences? Do you run any software to "enhance" the trackpad? Do you have any other input devices connected besides the trackpad and a mouse? If you have a mouse, does it have any driver or configuration software? Quote Link to comment
0 Elite Exhibits Posted June 10, 2022 Author Share Posted June 10, 2022 Pat Thanks as always ... FYI: Pre Pandemic - MacBook Pro 2013 with VW/RW Designer 2013 Post Pandemic - MacBook Pro 2021 with VW/RW Designer 2022 I am slowly (painfully!) learning to click once to select, then right click. Amaizing how many time I apply the wrong texture with key strokes executed for years. I do NOT utilize a mouse - I "right" click with the option key & track pad See the attached - went to the 2013 MacBook Pro / VW 2013 and used the same approach with out any issues ¿ Possibly something with the MacBook Pro ? Peter Click Right Click.mp4 Quote Link to comment
0 Pat Stanford Posted June 10, 2022 Share Posted June 10, 2022 Probably. Check the Trackpad setting for both machines and there is probably something set differently. Or by any chance do you have "extender" software to enhance the trackpad on either machine? Also, in the Keyboard System Preference pane, check the Modifier Keys... settings and make sure they are set the same. For me, "Right click" has always been Control, not Option, so did you change that back in 2013 and didn't think to do so for the new machine? HTH. Quote Link to comment
0 Elite Exhibits Posted June 10, 2022 Author Share Posted June 10, 2022 Pat Thanks You are correct - It is Control , not Option. No software extenders - I turn most of all of the Trackpad gestures off My Keyboard Modifier Keys matches your screen shot above Peter Quote Link to comment
0 Pat Stanford Posted June 10, 2022 Share Posted June 10, 2022 Can you create a file with a few resources that shows the problem for you and post it here. I can to duplicate the problem. Quote Link to comment
Elite Exhibits
Suggestions ?
Peter
7 answers to this question
