lfm1791 Posted May 7 Share Posted May 7 Is there a way to organize layers based on type? For example, Finish Floor or Ceiling Layers to be under a Parent “Finish Floors” or “Ceilings” where the multiple Finish Floors or Ceilings can be found for the various stories. The same for framing plans, slab plans, etc. Quote Link to comment
Pat Stanford Posted May 7 Share Posted May 7 Layers do not have any hierarchy like classes do. But you should be able to use the search feature of the Navigation palette to show you only the ones you want. Type "finish" or "ceilings" in the search box and you should get just the layers you are looking for. Quote Link to comment
Tom W. Posted May 7 Share Posted May 7 Or using Layer Filters gives you lots of options for varying which layers you see in the Navigation or Organisation palettes at any one time Quote Link to comment
halfcoupler Posted May 7 Share Posted May 7 Last year I worked on a project with over 100 individual drawings, each on a seperate design- and sheet layers. To keep control over this I grouped them by simply adding empty layers between each group. Not perfect, but it worked. 3 Quote Link to comment
lfm1791 Posted May 7 Author Share Posted May 7 Thank you all! Hopefully this is something VW is working on so you can group layers based on standard practice clasification. Quote Link to comment
jeff prince Posted May 7 Share Posted May 7 1 hour ago, lfm1791 said: Thank you all! Hopefully this is something VW is working on so you can group layers based on standard practice clasification. It’s entertaining to see your posts about how Vectorworks should behave as a new user from Revit. I came to Vectorworks from Autocad and had similar reactions. The sooner you give up on changing Vectorworks into Revit and take some time to get properly training, the sooner you will be happy and productive. Visit Vectorworks University, take the Fundamentals course to get the basics software organization and interface down. The take the Architectural learning path. You will find Vectorworks will do almost everything you need, just in a different way. Just don’t ask how to stack wall finished 🙂 Or, you can keep posting these Vectorworks ain’t Revit comments. Eventually, skilled contributors here will stop helping you. 3 Quote Link to comment
scottmoore Posted May 7 Share Posted May 7 5 hours ago, halfcoupler said: Last year I worked on a project with over 100 individual drawings, each on a seperate design- and sheet layers. To keep control over this I grouped them by simply adding empty layers between each group. Not perfect, but it worked. Actually, I use blank layers to break up my list of layers. This allows you to organize anyway you would like, and if instituted in your template, will make locating layers (and saved views by the way) much simpler. Quote Link to comment
lfm1791 Posted May 7 Author Share Posted May 7 Jeff - I appreciate the feedback and I have been going through many of the videos. They are helpful. It is fair for anyone coming in from other platforms to ask questions relative to what they have done for years. I do not believe many share the sentiment that you have as this is to be an informational and educational forum. If the intent is not assist, then this forum should not exist. thank you! Quote Link to comment
jeff prince Posted May 7 Share Posted May 7 1 hour ago, lfm1791 said: Jeff - I appreciate the feedback and I have been going through many of the videos. They are helpful. It is fair for anyone coming in from other platforms to ask questions relative to what they have done for years. I do not believe many share the sentiment that you have as this is to be an informational and educational forum. If the intent is not assist, then this forum should not exist. thank you! I was just trying to help. Good luck. Quote Link to comment
Christiaan Posted May 7 Share Posted May 7 5 hours ago, lfm1791 said: Thank you all! Hopefully this is something VW is working on so you can group layers based on standard practice clasification. I don't believe they are, but this is something I would like too. Quote Link to comment
Tom W. Posted May 7 Share Posted May 7 7 minutes ago, Christiaan said: I don't believe they are, but this is something I would like too. How would that work with the Top/Plan stacking order of the layers? If you want to see all the 'Finish Floor' layers together in a group don't you just create a 'finish floor' filter? I have probably misunderstood the question. I've not seen Revit Quote Link to comment
Christiaan Posted May 7 Share Posted May 7 (edited) 19 minutes ago, Tom W. said: How would that work with the Top/Plan stacking order of the layers? If you want to see all the 'Finish Floor' layers together in a group don't you just create a 'finish floor' filter? I have probably misunderstood the question. I've not seen Revit Stacking can still work. In fact I already bunch slab, floor, ceiling layers together on some projects. Slabs in a bunch at the bottom, floors in between and ceilings above. We could have a couple of new non-layer items alongside New Design Layer and New Sheet Layer: New Group - you'd get a choice to add layers when you create the Group, or you could drag layers into the Group once it's created. New Divider - for adding a visible divider between layers that isn't actually a layer I'd like this for Design Layers but I'd especially like to be able to group my Sheet Layers. Edited May 7 by Christiaan 4 Quote Link to comment
unearthed Posted May 7 Share Posted May 7 7 hours ago, jeff prince said: It’s entertaining to see your posts about how Vectorworks should behave as a new user from Revit. I came to Vectorworks from Autocad and had similar reactions. The sooner you give up on changing Vectorworks into Revit and take some time to get properly training, the sooner you will be happy and productive. Visit Vectorworks University, take the Fundamentals course to get the basics software organization and interface down. The take the Architectural learning path. You will find Vectorworks will do almost everything you need, just in a different way. Just don’t ask how to stack wall finished 🙂 Or, you can keep posting these Vectorworks ain’t Revit comments. Eventually, skilled contributors here will stop helping you. "The sooner you give up on changing Vectorworks", and this is true of working with any CAD; it's about picking the right tool and then setting your mindset for that tool, all CAD's differ on some many levels so with VW you need your VW hat on, likewise with ACAD, Rhino, Sketchup etc. 1 Quote Link to comment
jeff prince Posted May 7 Share Posted May 7 3 hours ago, Christiaan said: Stacking can still work. In fact I already bunch slab, floor, ceiling layers together on some projects. Slabs in a bunch at the bottom, floors in between and ceilings above. We could have a couple of new non-layer items alongside New Design Layer and New Sheet Layer: New Group - you'd get a choice to add layers when you create the Group, or you could drag layers into the Group once it's created. New Divider - for adding a visible divider between layers that isn't actually a layer I'd like this for Design Layers but I'd especially like to be able to group my Sheet Layers. I think this notion of grouping sheet layers is a good and important idea. I frequently create sets for different phases of design or iterations of a particular sheet during schematic design. Grouping sheets would be a nice way to organize the sheets into relevant stacks. Same logic for design layers applies. 1 Quote Link to comment
