Get Text Properties from Parent PIO
Hello there,
is it possible to get the the text style from the Parent PIO?
just asking to make my onject more customizable (i.e. switching font and font style)
Cheers!
Hi
You want to attach a Text property on a Marionette Object and then inside the Script ask for the Text Properties attached to the Marionette PIO? I think if a Marionette Object can get some infos from the text menu, it would be possible.
You can handle the Parent PIO, but I do not see, that a Marionette can get some text Infos by the text menu. You could get the class of the Parent PIO and the Text Style of the Class as a workaround maybe. But directly the Text Style I think works not with a Marionette Object Node.
Here An example, if you get the text style of the parent PIO class.
Side Note:
First Time I use concat node, it seems to convert the input list to a string instead of concat the input strings, which is somehow not what I would expect. It converts the List in a string first ...
TextStyleByPIO_class.vwx
Thank you very much!
I was aware of this method.
But what I wanted to achieve was, as you described not (yet?) possible = to change char Properties with the text settings in the "menu bar"
I dont't like the workaround with the styles (in case of copying the object in different files - i know you could genrate the style inside the network...)
But hey just keep it simple - for now i will sty with "Arial" 🙂
@Marissa Farrell@DomC Keep up your continuous quality posting! Cheers!
