The Batch Rename feature is nice, but could use some enhancements:
- I think the state of the tool should remain when re-opened in a session until changed. It’s tedious to constantly select type and process each time.
- I would really like the type selection to be check marks instead of a drop down, as it is quite possible one might need to change the name of multiple types of objects at the same time. Case in point, I have a specific template that requires up to 20 name changes and each name change applies to a class, sheet layer, saved view and two symbols. Because the state of the tool reverts each time and you can’t select more than on type of item, It’s only useful for the symbols. It’s faster to do everything else manually. It may be faster to rename the symbols manually in fact.
scottmoore
Just my opinion.
22 answers to this question
