Reordering id tags
michaelcobb
I have a problem with the id tags/schedule when one of the windows gets deleted (as requested by a client for example). I'd like the ID tags to reorder themselves so there isn't a missing entry. Robert I think we talked about this at the last SF vworks gathering. Any luck?
-Michael Cobb
Mike
mcobb@studioecesis.com
  • 2 weeks later...
Michael, I was a little "stung" by your last message [smile] so last weekend I set out to see if this functionality could in fact be done in a weekend. The answer is, "not quite", but in a weekend-evening plus half a week day it can. Later today there will be posted to the third-party plugin site a menu command called "Re-sequence Openings..." which will allow resequencing of door or window IDs.
This command will:
-work with VW Architect 12;
-allow you to set a starting number;
-work either on the active layer or all layers;
-remove "gaps" in door or window sequences;
-maintain the existing order of IDs;
-automatically "pad" IDs with leading zeroes for proper sort order.
The functionality will likely show up as a standard feature in future versions of VectorWorks Architect.
Wow. That sounds awesome. I'm sorry if I stung you. I'm not much of a diplomat. When I was finally able to meet you in person at the Vectorworks meeting in SF and you told me you were going to do it this weeekend I took you at your word and got REALLY excited. It did sound like a lot of work to me. Next time, if the request is gratuitous you can tell me to get lost. I can be pretty heavy with the requests (see other upcoming postings) and I am sure your job has other fish to fry.
Having said this I want you to know how much this change means to me. Any program can come up with new bells and whistles but I think this kind of basic improvement to an existing feature is/willbe what sets Vectorworks apart.
The doors and windows are soooo much better in 12. Thanks!!!!
  • 2 weeks later...
