Linear Light Best Practices
trashcan
I have art lights that I want to insert diffused type lamps in for my renders.
Here's what I've done:
  1. Modeled my art light's hardware
  2. Put a rectangle inside of the art light
  3. Converted the art light to a line light
Here's what that looks like:
The quality of light is closer to a non-diffused LED strip light than it is a diffused light.
In order to get a more diffused, uniform look, I cranked up the brightness values, the dimmer and changed the falloff to NONE.
Looks pretty good.
A couple of notes about using these types of lights that's helpful:
  • This help article is useful
  • These lights will only render in Renderworks modes ("shaded" will not work)
  • When you change light settings in the OIP, your entire canvas disappears consistently. Just switch to shaded and then back to your render mode and things will re-appear. This must be a bug!
  • Turning off "render geometry" does exactly that in the OIP.
A little confused that the light still is treated as many individual lights (at least that's how reflections are interpreting it):
6 answers to this question
Looks pretty good.
Was just dealing with this myself yesterday. Agreed on all the above. I was mocking-up ring light, & could not get the line light to produce  attractive usable output (actually lighting a subject, like irl, not just glowing) even tho I upped the output to something like 500%, so switched to adding another source to fake the output, something I hate to do.
Have you tried using a Glow Texture instead of Line Lights?
Back in 2017, former Vw employee @PVA - Admin JimW had this to say about Line Lights in the thread linked above:
Quote
Line Lights are splotchy and there isn't much we can do to fix it. The object is considered to be deprecated in most cases and I don't think it will be getting any love anytime soon.
2 hours ago, Mark Aceto said:
Line and Area Lights are more or less obsolete, so the best practice is to use something else (like the glow texture above).
Ah. Yes, thanks. I hadn't used em in some time, now I remember why.
