WhoCanDo Posted April 28, 2022 Share Posted April 28, 2022 Hi, I've written a macro to rename ( SetName ) my sheet names eg. Sht-1, Sht-2, Sht-3 to Sht-2, Sht-1, Sht-3 However, ideally, I would like to change the stacking order. Is there a procedure or function to do this ? Quote Link to comment
MullinRJ Posted April 28, 2022 Share Posted April 28, 2022 Did you try HMoveForward() and HMoveBackward()? Raymond Quote Link to comment
michaelk Posted April 28, 2022 Share Posted April 28, 2022 I've been using this script for a while. It doesn't check for temporary duplicate sheet numbers. So I will add an X in the suffix field or a crazy prefix field, run the script, run it again and set it to what I really want. Let me know if that doesn't make sense 🙂 {Badly scripted by Michael Klaers} {March 2020} PROCEDURE RenumberSheetLayers; VAR LayerInQuestion :HANDLE; LyrTypInt, Counter, StackOrderBegin, StackOrderEnd, RenumStart, RenumCount, HowManyLayers, NumDesignLayers, id, item : INTEGER; SheetPrefix, SheetSuffix, NewName, TempString : STRING; Bool :BOOLEAN; {******************************** The ever confusing dialog handler ****************} PROCEDURE Dialog_Handler(VAR item :LONGINT; data :LONGINT); BEGIN CASE item OF SetupDialogC: BEGIN Bool := GetSavedSetting('SLRename','StackOrderBegin',TempString); SetEditInteger(id,6,Str2Num(TempString)); Bool := GetSavedSetting('SLRename','StackOrderEnd',TempString); SetEditInteger(id,7,Str2Num(TempString)); Bool := GetSavedSetting('SLRename','SheetPrefix',TempString); SetItemText(id,12,TempString); Bool := GetSavedSetting('SLRename','RenumStart',TempString); SetEditInteger(id,13,Str2Num(TempString)); Bool := GetSavedSetting('SLRename','SheetSuffix',TempString); SetItemText(id,14,TempString); END; 1: BEGIN Bool := GetEditInteger(id,6,StackOrderBegin); Bool := GetEditInteger(id,7,StackOrderEnd); GetItemText(id,12,SheetPrefix); Bool := GetEditInteger(id,13,RenumStart); GetItemText(id,14,SheetSuffix); END; 2: BEGIN END; END; {Case} END; {Dialog Handler} {******************************** The slightly less confusing dialog layout ****************} PROCEDURE MakeMeADialogBox; BEGIN id:=CreateLayout('Renumber Sheet Layers',TRUE,'OK','Never Mind'); CreateStaticText(id,4,'First',-1); CreateStaticText(id,5,'Last',-1); CreateEditInteger(id,6,1,6); CreateEditInteger(id,7,1,6); CreateStaticText(id,9,'Prefix',-1); CreateStaticText(id,10,'Num',-1); CreateStaticText(id,11,'Suffix',-1); CreateEditText(id,12,'A',6); CreateEditInteger(id,13,0,6); CreateEditText(id,14,'',6); SetFirstLayoutItem(id,4); SetRightItem(id,4,6,0,0); SetBelowItem(id,4,5,0,0); SetRightItem(id,5,7,0,0); SetBelowItem(id,5,9,0,0); SetRightItem(id,9,10,1,0); SetRightITem(id,10,11,2,0); SetBelowItem(id,9,12,0,0); SetBelowItem(id,10,13,0,0); SetBelowItem(id,11,14,0,0); SetHelpText(id,4,'Stacking order of first sheet to be renumbered'); SetHelpText(id,6,'Stacking order of first sheet to be renumbered'); SetHelpText(id,5,'Stacking order of last sheet to be renumbered'); SetHelpText(id,7,'Stacking order of last sheet to be renumbered'); SetHelpText(id,9,'New prefix for renamed sheet layers'); SetHelpText(id,12,'New prefix for renamed sheet layers'); SetHelpText(id,10,'New starting number for renamed sheet layers'); SetHelpText(id,13,'New starting number for renamed sheet layers'); SetHelpText(id,11,'New suffix for renamed sheet layers'); SetHelpText(id,14,'New suffix for renamed sheet layers'); END; BEGIN {**** MAIN ****} MakeMeADialogBox; item := RunLayoutDialog(id, Dialog_Handler); IF item = 1 THEN BEGIN {MESSAGE ('Stacking Begin: ',StackOrderBegin,CHR(13), 'Stacking End: ',StackOrderEnd,CHR(13), 'Prefix: ',SheetPrefix,CHR(13), 'RenumStart: ',RenumStart,CHR(13), 'Suffix: ',SheetSuffix);} Counter := 1; LayerInQuestion:=FLayer; HowManyLayers := NumLayers; RenumCount := RenumStart; For Counter := 1 to HowManyLayers DO {Step through every layer, including Design Layers} BEGIN LyrTypInt := GetObjectVariableInt(LayerInQuestion,154); {***************************************************************************} {Layer type 1 is a design layer. It counts them from the bottom of the stack to the top. Ignore and go to the next layer. But count how many design layers there are. You'll need that later.} IF LyrTypInt = 1 THEN Begin NumDesignLayers := Counter; End; {***************************************************************************} {Now we're in business. Layer type 2 is a Sheet Layer Sheet Layers are counted by stacking order from top to bottom.} IF LyrTypInt = 2 THEN BEGIN IF (StackOrderBegin <= (Counter-NumDesignLayers)) AND ((Counter-NumDesignLayers) <= StackOrderEnd) THEN BEGIN NewName := CONCAT(SheetPrefix,Num2Str(0,RenumCount),SheetSuffix); SetName(LayerInQuestion,NewName); RenumCount := RenumCount + 1; END; {IF counter is in change range} END; {If LyrTypInt is 2 (i.e. Sheet Layer} {***************************************************************************} LayerInQuestion:=NextLayer(LayerInQuestion); END; {1 to number of layers} SetSavedSetting('SLRename','StackOrderBegin',Num2Str(0,StackOrderBegin)); SetSavedSetting('SLRename','StackOrderEnd',Num2Str(0,StackOrderEnd)); SetSavedSetting('SLRename','SheetPrefix',SheetPrefix); SetSavedSetting('SLRename','RenumStart',Num2Str(0,RenumStart)); SetSavedSetting('SLRename','SheetSuffix',SheetSuffix); END; {If user clicked OK} END; {main} RUN(RenumberSheetLayers); Quote Link to comment
