why is my " focus beam" on an angle and i can't change it ?
Flavie
If the Focus Point is directly under the Lighting Device then the Beam should be aligned correctly. However, if it is slightly un aligned then the focus can become un-rotated. To return it to where you need it to be then use the Lamp Rotation Angle field and you can rotate it to any angle you want.
