why is my " focus beam" on an angle and i can't change it ?
If the Focus Point is directly under the Lighting Device then the Beam should be aligned correctly. However, if it is slightly un aligned then the focus can become un-rotated. To return it to where you need it to be then use the Lamp Rotation Angle field and you can rotate it to any angle you want.
