Bruce Kieffer Posted April 23, 2022 Share Posted April 23, 2022 Is there a way to set Shaded for Detail Very High by default? It seems to revert to low a lot for me. Quote Link to comment
0 Tom W. Posted April 23, 2022 Share Posted April 23, 2022 It should stay at whatever you set it to for the document. If you use a template + have it set to very high there + all your documents use that template then the setting should always be very high. The default blank file is set to low I think so if you use this regularly you can edit the shaded settings for that file in the application Defaults > Templates folder. Or maybe the way to do it is to put your own version of the 'blank.sta' file in the user template folder...? 2 Quote Link to comment
0 Bruce Kieffer Posted April 23, 2022 Author Share Posted April 23, 2022 Thanks @Tom W.I found the problem. Some of my saved views were saved with the Shaded Detail set to Low. When I change those to Very High then the setting sticks. Quote Link to comment
Bruce Kieffer
2 answers to this question
