CW2020 Posted April 20, 2022 Share Posted April 20, 2022 (edited) I wrote about this topic recently, but can't find the thread. Every time I turn off VW the pallettes I have turned on in Navigation and Object Info turn off. I created a new workspace from scratch just to address this, and after a few sessions it began doing this again. Edited April 20, 2022 by CW2020 Quote Link to comment
CW2020 Posted May 4, 2022 Author Share Posted May 4, 2022 (edited) Before I again remove the program and re-install, I'm wondering if a VWX tech has any input on this issue... still happening every time I close the program? And yes, I'm selecting Save Pallette Positions and Save Workspace repeatedly. Edited May 4, 2022 by CW2020 Quote Link to comment
Pat Stanford Posted May 4, 2022 Share Posted May 4, 2022 It sounds like it may be corruption in your user folder or in the application preferences. What operating system and VW version are you running? Have you gone to Vectorworks Preferences and clicked the Reset button at the bottom left? If you have then I would try removing the preference plist file manually and restarting VW. You will have to reenter your serial number if you do that. Or do a full uninstall prior to reinstalling. It kind of sounds like VW is being unable to save the preferences properly when you quit. Save Palette Positions really only does anything if VW happens to crash. If you exit normally, the palette positions are resaved based on what was active when you quit. 2 Quote Link to comment
CW2020 Posted June 3, 2022 Author Share Posted June 3, 2022 Hey Pat. Sorry for the delayed reply. Finally uninstalled and reinstalled. Things are running better. Your response was thorough and helpful as always. 1 Quote Link to comment
