Wall Textures
msclark
I am unable to asign a image texture to a wall after It has been created. I first added the texture to the wall type and it did not update the existing walls, though if I draw a new wall with that type the texture shows up. Then i tried assigning the texture to the wall's class, which did not work either. At the same time this was happening, the wall was refusing to change class. If I changed the class, the next time I selected it it would be reverted back to it's original class. I tried everything I could think of but it seems like a bug to me. Anyone had any similar problems or a solution?
Thanks, Matt
