msclark Posted January 11, 2006 Share Posted January 11, 2006 I am unable to asign a image texture to a wall after It has been created. I first added the texture to the wall type and it did not update the existing walls, though if I draw a new wall with that type the texture shows up. Then i tried assigning the texture to the wall's class, which did not work either. At the same time this was happening, the wall was refusing to change class. If I changed the class, the next time I selected it it would be reverted back to it's original class. I tried everything I could think of but it seems like a bug to me. Anyone had any similar problems or a solution? Thanks, Matt Quote Link to comment
msclark Posted January 11, 2006 Author Share Posted January 11, 2006 I answered it myself, except the changing class part-thanks though - Matt Quote Link to comment
MKingsley Posted January 15, 2006 Share Posted January 15, 2006 You may have figured this out already but if you have "auto-classing" checked in the Standard Naming dialog, it won't let you change the class from what it was given at creation. Unchecking that will let change classes for that object HTH, Michael Quote Link to comment
