How to get these parameters?
Mouldings Plugin are not developed with the SDK, but in VectorScript (event driven plugin objects).
In Vectorscript there is no GetTextureMappingInfoN() function.
I am still searching a way to customise the render pane, but until now, I did not found any satisfying solution.
I do not know why if you create e 3D object (e.g. a simple extrusion) you get the full options on the object render pane, while if you create a 3D object through a plugin object, the object render pane is limited to the texture popup and texture choices.
Somebody knows why?
