MaltbyDesign Posted April 13, 2022 Share Posted April 13, 2022 When I model walls, I like to create wall types made up of components which can be seen on plan but for some presentations it's nice to show walls as solid black. I thought there was an easy way to do this but I can't seem to find it. Any tips or directions to a tutorial that explains how this can be done? Thanks in advance. Quote Link to comment
Jeff Prince Posted April 13, 2022 Share Posted April 13, 2022 Turn off your component classes and change your wall’s container class to have the graphic qualities you desire? 2 Quote Link to comment
michaelk Posted April 14, 2022 Share Posted April 14, 2022 In the viewport set the Detail Level to Low. All the walls should lose their components. As far as I know that's a VW-wide setting that isn't editable. I know you can't change it on a per wall style basis. I use Data Visualization to change the graphic attributes per viewport (white fill for existing, dark fill for new, no fill + dashed line for demo). The easiest attributes to use are a record format attached to the walls, but you could also use class. 3 Quote Link to comment
Pat Stanford Posted April 14, 2022 Share Posted April 14, 2022 I agree with @michaelk Data Visualization will be the easiest way to set the walls to a solid black for just some presentation modes. 1 Quote Link to comment
Peter Vandewalle Posted April 14, 2022 Share Posted April 14, 2022 For viewports, set the detail level to 'low'. Make sure your walls use class settings for a fill (Edit Wall Attributes). Use class overrides to make the wall classes fill black. For section viewports, just open the advanced properties, 'attributes' tab. Check 'Merge Cross Sections'. The section will use the 'Section Style' class for attributes. Change that class's attributes to black or use the class overrides for that class. 2 Quote Link to comment
Tom W. Posted April 14, 2022 Share Posted April 14, 2022 Just to say the advantage of the @jeff prince method is that you retain the detail level in other objects should that be desired. 3 Quote Link to comment
MaltbyDesign Posted April 14, 2022 Author Share Posted April 14, 2022 15 hours ago, michaelk said: In the viewport set the Detail Level to Low. All the walls should lose their components. As far as I know that's a VW-wide setting that isn't editable. I know you can't change it on a per wall style basis. I use Data Visualization to change the graphic attributes per viewport (white fill for existing, dark fill for new, no fill + dashed line for demo). The easiest attributes to use are a record format attached to the walls, but you could also use class. Thanks for this. Where can I find out how to implement Data Visualization? That sound like what I need; a way to easily differentiate between existing, new and demo. Quote Link to comment
michaelk Posted April 14, 2022 Share Posted April 14, 2022 Your signature says you're using 2015. Is that still true? Quote Link to comment
michaelk Posted April 14, 2022 Share Posted April 14, 2022 Here's an example with walls. Keep in mind that this works with ANYTHING (…almost!) Wall Data Vis Example.vwx Quote Link to comment
MaltbyDesign Posted April 14, 2022 Author Share Posted April 14, 2022 29 minutes ago, michaelk said: Your signature says you're using 2015. Is that still true? No. And I can't see where to change my signature. This came up before and I checked my profile settings but don't see it anywhere. Used to see it under my name but something appears to have changed with how the forum is set up. Quote Link to comment
MaltbyDesign Posted April 14, 2022 Author Share Posted April 14, 2022 24 minutes ago, michaelk said: Here's an example with walls. Keep in mind that this works with ANYTHING (…almost!) Wall Data Vis Example.vwx 4.74 MB · 0 downloads That looks interesting but what I don't understand is how you apply the existing, new and demo characteristics to the wall. I see in the Properties Data tab you have the three phases in a drop down. How do I do this with my own wall types? Is there a tutorial on this that you could direct me to? I'm using VW2022. Quote Link to comment
Pat Stanford Posted April 14, 2022 Share Posted April 14, 2022 Signature is changed under Account Settings:Signature not under profile. I always forget that also. 1 Quote Link to comment
Jeff Prince Posted April 14, 2022 Share Posted April 14, 2022 6 minutes ago, MaltbyDesign said: That looks interesting but what I don't understand is how you apply the existing, new and demo characteristics to the wall. I see in the Properties Data tab you have the three phases in a drop down. How do I do this with my own wall types? Is there a tutorial on this that you could direct me to? I'm using VW2022. If you go the data visualization route, there is an excellent tutorial on Vectorworks University where they demonstrate this technique on a remodel project. "REFURBISHMENT WORKFLOWS: CONSTRUCTION PHASING USING RECORD FORMATS AND DATA VIS" 2 Quote Link to comment
michaelk Posted April 14, 2022 Share Posted April 14, 2022 Definitely check out the VW University. Data Vis is a game changer. I use the Data Manager to attach a record format to every wall. It has a field with that pull down for New, Existing, Demo. Then create a new Data Visualization that looks for that field and assigns graphic attributes. 2 Quote Link to comment
michaelk Posted April 14, 2022 Share Posted April 14, 2022 In the top bar of Vectorworks check to see if you have the Data Vis pulldown checked. (that triangle to the far right has a list of what's visible) I'm not sure if there is another way to get to Data Vis??? 1 Quote Link to comment
MaltbyDesign Posted April 14, 2022 Author Share Posted April 14, 2022 1 hour ago, jeff prince said: If you go the data visualization route, there is an excellent tutorial on Vectorworks University where they demonstrate this technique on a remodel project. "REFURBISHMENT WORKFLOWS: CONSTRUCTION PHASING USING RECORD FORMATS AND DATA VIS" Thanks for that, Jeff. I'll go have a look at that. This seems to be a really logical way to control visualization for phasing. 1 Quote Link to comment
Tom W. Posted April 14, 2022 Share Posted April 14, 2022 2 hours ago, michaelk said: I use the Data Manager to attach a record format to every wall. It has a field with that pull down for New, Existing, Demo. @michaelk do you have a single container class for all your Walls or do you use a 'Demo' one to allow you to make the to-be-demolished Walls invisible? I so need to start using the Data Manager I'm relying on you to keep recommending it + eventually I will do! 🙂 Quote Link to comment
MaltbyDesign Posted April 14, 2022 Author Share Posted April 14, 2022 3 hours ago, jeff prince said: If you go the data visualization route, there is an excellent tutorial on Vectorworks University where they demonstrate this technique on a remodel project. "REFURBISHMENT WORKFLOWS: CONSTRUCTION PHASING USING RECORD FORMATS AND DATA VIS" Sadly, I can't find a tutorial by this name. Are you able to share a link? Quote Link to comment
michaelk Posted April 14, 2022 Share Posted April 14, 2022 22 minutes ago, Tom W. said: @michaelk do you have a single container class for all your Walls or do you use a 'Demo' one to allow you to make the to-be-demolished Walls invisible? I usually use a demo class and often a demo design layer if it gets too busy and fussy. Especially if there are two or more phases of demo. One of the great things about Data Vis is that you can cut down on the number of classes for walls. (and other things) I made a couple scripts with keyboard shortcut to move objects up and down the layer stack so I can do it without taking my hands off the keyboard. That makes zipping objects off to a demo layer to be sorted at my leisure more efficient. 2 Quote Link to comment
michaelk Posted April 14, 2022 Share Posted April 14, 2022 Check these out: A GUIDE TO DATA VISUALIZATION WITH VECTORWORKS LIVE DATA VISUALIZATION REAL-TIME AUDIT OF 3D MODELS USING DATA VISUALIZATION MODEL SETUP FOR RENOVATION PROJECTS DATA VISUALIZATION FOR THE DECISION-MAKING PROCESS 1 Quote Link to comment
Tom W. Posted April 14, 2022 Share Posted April 14, 2022 24 minutes ago, michaelk said: I usually use a demo class and often a demo design layer if it gets too busy and fussy. Especially if there are two or more phases of demo. One of the great things about Data Vis is that you can cut down on the number of classes for walls. (and other things) I made a couple scripts with keyboard shortcut to move objects up and down the layer stack so I can do it without taking my hands off the keyboard. That makes zipping objects off to a demo layer to be sorted at my leisure more efficient. I use '-Existing', '-Proposed' + '-Demolished' Wall classes which I'd still need to use in order to change visibility. So I'm not totally sure what the advantage would be of introducing an existing/proposed/demo Record Format into the mix as well + using Data Viz to control the appearance of those Walls rather than doing it via class attributes but I guess I ought to give it a go + find out... Quote Link to comment
Jeff Prince Posted April 14, 2022 Share Posted April 14, 2022 3 hours ago, MaltbyDesign said: Sadly, I can't find a tutorial by this name. Are you able to share a link? https://university.vectorworks.net/mod/page/view.php?id=931 2 Quote Link to comment
MaltbyDesign Posted April 18, 2022 Author Share Posted April 18, 2022 On 4/14/2022 at 4:37 PM, jeff prince said: https://university.vectorworks.net/mod/page/view.php?id=931 Thanks very much, Jeff! 1 Quote Link to comment
