Can't Seem to Replicate Styled Wall's Material/Texture
CW2020
I'm working on a 3D project and was trying to deconstruct how the materials/texture was added. To no avail. Now I can't seem to get materials/textures to show on a couple new walls I created; checked wall styles, class settings, rendering settings.
To be clear, I attached a screenshot of what I'm seeing. There's three walls. One is from a project I just started and I can see the siding (material or texture) on that wall. I can't determine where that specific  siding info has been entered. Additionally I created a couple of walls quickly. Under Wall Component Settings I have one unsettled wall with the exterior component checked for "Use material" and texture... brick on both. Brick on both sides of the wall as well. The other wall is styled and similarly I tried to add material/texture siding at every attribute I could.
WALL STYLES.vwx
Edited by CW2020
Thank you! Extremely helpful! And here's the thing, I'm working on my recently refurbished 2016 MacBook Pro running 2022VWX. And every time close and reopen VWX all of my pallets in Navigation (except Classes) and Object Info (except Shape) turn off. I'm using the same Workspace. And I've selected Save Pallette Positions multiple times. So I have to constantly turn the other relevant pallettes on. And over time, I've just forgotten about that Render pallete since I all-but-never work in 3D. Anyways. Thanks. And if you want help me as to why all my pallettes turn off, that'd be great
Hiding palettes sounds like it might be a corrupted workspace.
Try one of the stock workspaces and see if that functions properly. If it does, then you need to recreate your workspace starting from one of the stock versions.
Recreation is not a lot of fun, but doing it every version or two can save a lot of trouble.
