RuiSantos___ Posted April 11 Share Posted April 11 Dear community, I would like to know if there is any way I could do a Green Wall? I've tried (with no success) applying a texture, but the result is far from what I want. I've tried do create a grass texture, but when applied, it just appears to be flat green... I don't know if I could use the curtain wall or if I should do it on other way. I've attached the file. Regards. Parede Verde.vwx Quote Link to comment
jeff prince Posted April 11 Share Posted April 11 I’ve done these in the past by drawing my conventional wall the greenwall attach to and then add a modeled object representing the selected greenwall system. Vectorworks has a few in the library that may work well or at least present the methodology for displaying the plants. A decal works well to depict the plants. several manufactures provide models for their systems which may be helpful. I recommend importing those into a separate vectorworks file and adjusting/cleaning them up prior to using in your building model to prevent gremlins arising. Quote Link to comment
RuiSantos___ Posted April 11 Author Share Posted April 11 1 hour ago, jeff prince said: I’ve done these in the past by drawing my conventional wall the greenwall attach to and then add a modeled object representing the selected greenwall system. Vectorworks has a few in the library that may work well or at least present the methodology for displaying the plants. A decal works well to depict the plants. several manufactures provide models for their systems which may be helpful. I recommend importing those into a separate vectorworks file and adjusting/cleaning them up prior to using in your building model to prevent gremlins arising. Thanks for your reply, but I couldn't find any Greenwall systems in VW Library, can you show me where are they? Quote Link to comment
jeff prince Posted April 11 Share Posted April 11 (edited) 2 hours ago, _leorus said: Thanks for your reply, but I couldn't find any Greenwall systems in VW Library, can you show me where are they? search resource manager for “greenscreen” for an example of systems. Edited April 11 by jeff prince Quote Link to comment
