Newbie Dimensioning Question
Hi,
I just purchased VW12 Designer after years of frustration with Archicad.
Here's my question: when dimensioning walls with components, I see that the dimensions won't associate (i.e. move with a wall) unless I dimension to the outside of the wall.
If my wall has 2x4 studs + 1/2" plywood + 1" stucco, I don't want to dimension to the outside of the stucco. However, if I offset to the edge of the 2x4s and plywood - where one would want to dimension normally - the dimensions won't move when I move the wall.
How do people get around this? When dimensions don't move with walls, it's an invitation to mistakes and busy-work try to double check and redimension properly.
Thanks
Mightyquinn
