Changing the Lights in "ALL" doesn't change the lights for all viewports once you click away. Reverting viewports to no overrides on lighting doesn't change anything. Restarting the program will make it work again. But for how long!?
After not using VWX for a minute I forgot how often a problem is solved by just restarting the application. It's more likely the program is doing something wrong than you are !
trashcan
0 answers to this question
