loretta.at.large Posted March 29 Share Posted March 29 Hi All, I'm curious to know if anyone else has been having problems with rendering landscapes over the last 2 years. I've been doing 3d modeling for several years now in Vectorworks and used to feel that things were getting better and better. But recently I've been struggling to get the same quality of renderings that I had in the past. I will try to summarize my main issues here: - SHADED renderings mode: Shadows either don't show up at all or come out looking extremely pixelated even when the Shadow quality is set to "High". For the most part, everything else looks okay and image props render normally. - REALISTIC rendering mode: Image props render in an unpredictable manner. Some render with a transparent background while others do not. Also, some objects rendering with strange gaps despite being solid. Again, some object render normally while others don't... doesn't seem to matter if it's a flat object or curved, but curved surfaces seem to have more problems. I have played around with ALL the settings and even tried to create brand new image props through different methods to no avail. I also sometimes end up with weird phantom linework that doesn't exist in the file... it just shows up. Below are some screenshots so you can see what's going on: SHADED example: REALISTIC example: I'd also like to mention that I've tried using Twinmotion to see if I could get better results. Most objects render better, but the image props transfer as obvious planes, so the program is not seeming particularly helpful to me at this time. I've also tried rendering in Vectorworks Cloud and the images come out exactly the same as if I had rendered them locally on my MacBook. Using the iMac at the office hasn't yielded better results either. Quote Link to comment
jeff prince Posted March 29 Share Posted March 29 Are your objects far from the origin? That always seems to be when I see odd render behavior. The plant objects having transparency issues… are these plants that came with Vectorworks or ones you created? If the latter, it’s likely the unresolved/unexplained issue linked in my signature that tech support has dodged for years. 1 Quote Link to comment
loretta.at.large Posted March 30 Author Share Posted March 30 @jeff prince - It was the internal origin! Ugh... you're a lifesaver. I was losing my mind. 1 Quote Link to comment
jeff prince Posted March 30 Share Posted March 30 6 hours ago, loretta.at.large said: @jeff prince - It was the internal origin! Ugh... you're a lifesaver. I was losing my mind. Glad it helped. I’ve been there before… the losing my mind part and all 🙂 Quote Link to comment
loretta.at.large Posted March 30 Author Share Posted March 30 So much better. Now I can focus on all the other screwy stuff going on... like the horrible water texture and the car rotation that makes it look like it has a flat tire. Quote Link to comment
jeff prince Posted March 30 Share Posted March 30 If that hardscape the car is sitting on is not flat, you can align the car to the 3D plane best established by the area the car sits over using the work plane tool. water texture is always trial and error when it comes to lighting, transparency, and material behind it. You’ll get it to where you like soon 🙂 Quote Link to comment
