Junglejim Posted February 27, 2006 Share Posted February 27, 2006 I am just started using v12 and in 11.5 when I used a plant group there was a line between the plants. In v12 there isn't. I would like help getting the line back Jim Quote Link to comment
Guest Posted February 27, 2006 Share Posted February 27, 2006 You can change the line in the plant group by changing the option on the object info palette labeled "Polygon Display" once the plant group is selected. If you want to have it draw lines by default for that plant, you can edit the plant definition, and on the "Default Prefs" tab it has the same "Polygon Display" pull down menu that will set the default for that plant. Quote Link to comment
