V12 Line between plants in group missing
Junglejim
You can change the line in the plant group by changing the option on the object info palette labeled "Polygon Display" once the plant group is selected.
If you want to have it draw lines by default for that plant, you can edit the plant definition, and on the "Default Prefs" tab it has the same "Polygon Display" pull down menu that will set the default for that plant.
