oldnewguy Posted March 24 Share Posted March 24 what is the best way to do this? Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted March 24 Vectorworks, Inc Employee Share Posted March 24 If only for scale, the fastest method is simply extruding a 1'x2' oval to 6' +/- a bit. Otherwise, Pat mentions Image props. Search the resource manager for "people" and use the resulting image props found. Quote Link to comment
oldnewguy Posted March 24 Author Share Posted March 24 i looked for person, human, etc... people! Thanks. 1 Quote Link to comment
scottmoore Posted March 29 Share Posted March 29 (edited) Another option is getting a silhouette online and import the image. Enact the trace bitmap tool, clean up the resulting geometry. Add a fill and then extrude by an 1” or so. Don’t forget to rotate them upright and set their feet at Z=0. The advantage is it will show up correctly regardless of rendering type. bonus points by assigning the piece of extrusion to a class and set their fill color and texture by class. You can add some text or 2D geometry in plan view and then turn all that into a hybrid symbol. Now you can change the appearance of all your little silhouette people in one step by changing the class texture/color. Want them to be semi transparent? No problem. Want them to be blue? Easy. Want them to glow? Why not. Want them to appear to be on fire? Ok, but why? Edited March 29 by scottmoore Quote Link to comment
