RenderMall Plants install?
techdef
Looking for some help, I just sprung for the RenderMall plants package and am not having any luck installing them per the supplied file.
File says to place all contents into /Defaults/VBvisual Plant, which I tried and while it shows in the resource palette, the tool didnt recognize them.
PS> this is shooting for Workgroup install. I dont keep anything locally due to frequent work-from-home.
Should they be in a /Rendermall folder or something??
4 answers to this question
What “tool” are you referring to?  The VBvisual Plant tool or the Landmark Plant Tool?
In VW2022 'VBvisual Plant' was renamed 'RenderMall Plant'. I think you have to place the files in the 'RenderMall Plant' application folder. I'm not sure why it doesn't work when you put them in the user folder instead...
@Tom W., thanks, I'm not sure why this istn really working either. Putting it into the /Rendermall Plant folder definitely helped, but they're still not working right (ie: cant change sizes or seasons w/ the pulldown). Tech support doesnt seem to speak english. This may be an issue.
