Instrument Summary VERRYYY Slow
  1. Are you placing the summary for the first time in the drawing you're working in?
  2. Or has you already built the first one and now you're placing it again?
  3. How many different symbols is it trying to include?
I get beach balls when I have a large number of items and the tool is trying to build the list of symbols to include on its own.
Scott.
My common workflow is to place one summary with all of the devices used in my drawing. Following that I will copy/paste additional summaries and use Filter to refine the information that is shown. It is here that things begin to slow down.
I would say I have around 15 symbols in total.
So it sounds like it's something related to the filtering. What happens if you delete the unwanted items vs. filtering them out?
purging did a lot for me already though the summary is still very inconsistent, i always have issues with being slow as well as not displaying the fixture names at publishing etc...in this regard it helps if i copy/delet/insert in place but this "workflow" does anoy me a lot since i never kow if my publishing task of 10 plus sheets goes well or not
however i will send you the file to have a look at it.
thanks
Michael
  • 4 months later...
  • 2 weeks later...
@mkueI noticed you mentioned the Instrument Summary not displaying fixture names. I have had that issue in the past and pulled my hair out for a very long time trying to figure out why it sometimes would disappear and but most of the time it would not. What I found was that on a published sheet where it appeared the fixture names weren't displayed I was able to zoom in a very long way and the text there but was miniature.
What I was doing was placing the Instrument Summary directly onto the Sheet Layer.
What I now do is create a Design Layer at 1:1 scale and place the Instrument Summary on that. It is the only thing on that Design Layer. I then create a viewport of the Instrument Summary Sheet Layer on the Design layer and can then scale it as needed to fit. I have never had the text disappear since.
I hope this fixes one of your issues.
  • 6 months later...
Is this from a file you created prior to 2023? Or are you using your own content/symbols created in an earlier version of Vectorworks?
If this is a brand new file using Vectorworks Stock Symbols and you are getting this performance issue please can you email in the file or post here?
Have you tried the new graphic legends yet?
  • 4 weeks later...
I'm still seeing this behavior in 2023 as well.
The file started in versions prior to 2023, but that is not uncommon when working with venue-provided files, or repeating projects. Venue-provided files also may use non-stock symbols.
I'm interested in the graphic legends  but don't have the time right now to lean and troubleshoot a new elements.
  • 4 weeks later...
This has been occurring with me for a while, but I seem to only notice it on old files (created before 2023 and upconverted).
Unfortunately, this is our main workflow, updating shows each year without starting from scratch - especially if the scenic hasn't changed.
Curious if there's any fix planned for this.
Knowing it's been an issue forever, I try to edit the Instrument Summary only once a day or at the end of the project before publishing, so I can go get some coffee and wait 10 minutes for the dialog to open.
Try the attached plug-in by putting it in the Plug-Ins folder inside your VW user folder and then adding the menu command to your workspace.  It is an AutoPlot Plug-in, but it is fully functional for 2 months from the first time you try to use it.  It is faster than the Instrument Summary, and it reports the selected mode, but it is not a plug-in object, so you will have to re-run the command if you want to change the settings.  Let me know if you have any questions or problems.
Sam
sjones@autoplotvw.com
AP Instrument Summary.vsm
  • 3 months later...
Fyi, I can finally share...
The summary key has been completely rebuilt for 2024 and is performing much faster. It retains 90% of what was there, but adds the ability to add all entertainment objects into the key. Looking forward to seeing what people think.
We're working on that last 10% 🙂
  • Like 3
