livespace josha Posted March 17 Share Posted March 17 I have a worksheet that populates with device name, make, model, location, page number, and some custom fields for serial number and IP address However, this report also pulls connector panels because they become devices once they are in the design layer. Is there a fancy script or criteria that I can use to omit these from my report? I'd prefer this to be something native that I don't have to think about or remember to do! I have a work-around in mind that could use Data Manager, but that might be a plan B. Quote Link to comment
Pat Stanford Posted March 17 Share Posted March 17 Is there a field that specifies the connector panels? If so an added criteria of Record.Field Is Not (whatever the specifier is) should remove them from the report while leaving everything else. 1 Quote Link to comment
aheininen Posted March 18 Share Posted March 18 I have used this criteria on worksheet. This assumes that you don't specify Make to your panels. Quote Link to comment
livespace josha Posted March 18 Author Share Posted March 18 perfect! I had to change the criteria to say "is not" "blank" Quote Link to comment
