Ramon PG Posted March 17 Share Posted March 17 I get double entries when Spaces are NOT duplicated. I make all layers and classes visible and there are only 23 Spaces. Quote Link to comment
0 Pat Stanford Posted March 17 Share Posted March 17 What is the criteria you are using in the worksheet? It is likely that you have a copy of the space in a Design Layer viewport and the worksheet is reporting both instances. Edit the criteria to include the Layers(s) that you want to report spaces on and you should eliminate the duplicates. 1 Quote Link to comment
0 Ramon PG Posted March 17 Author Share Posted March 17 44 minutes ago, Pat Stanford said: What is the criteria you are using in the worksheet? It is likely that you have a copy of the space in a Design Layer viewport and the worksheet is reporting both instances. Edit the criteria to include the Layers(s) that you want to report spaces on and you should eliminate the duplicates. Cannot thank you enough. For some forgotten reason there was a design VP hidden there. Rascal... Thanks again. Quote Link to comment
Ramon PG
2 answers to this question
