elc Posted March 16, 2022 Share Posted March 16, 2022 hello, to save time, I am copy-pasting equipment from room to room or within a room and then bulk-update the device name with the find and replace function. so far so good. unfortunatelly linked equipment (espcacially rack location, in-rack position and slot number) is not updated accordingly. Updating PIO (Extras>Intelligente Objekte aktualisieren // Tools>Update POI) does not work either. So I have to go to the OIP of each device, change the name to something non existing, confirm and then change it to the correct device/equipment name. ...not really the time-saver I was hoping for. 😉 am I missing something? thanks, george Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted March 17, 2022 Vectorworks, Inc Employee Share Posted March 17, 2022 I don't think you are missing anything unfortunately. Poking a new value in won't trigger the action to join everything up. But it would be nice if it did... given us something to think about! Conrad 1 Quote Link to comment
CalebD Posted August 24, 2022 Share Posted August 24, 2022 I think I'm hitting this same limitation as well. I created devices on the schematic layer, used them to create 2D rack elevations, then needed to update the schematic objects. I copy/pasted an updated object and renamed each copy 'back to' the former name (IE, copied AMP-01 a few times, renamed the copies AMP-02, -03, etc). The Device Name (schematic layer) isn't updating, and it's still showing the rack name and rack RU of AMP-02, even though the info in OIP is correct/updated. It seems like the dynamic link between the two (schematic and rack elevation) is 'weak' with only some parameters being dynamically linked. Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted August 24, 2022 Vectorworks, Inc Employee Share Posted August 24, 2022 Thanks @CalebD I'll check and see what I find out. Conrad Quote Link to comment
elc Posted March 30, 2023 Author Share Posted March 30, 2023 minor update: still seems to be an issue in SP4 current workaround: just creatin a worksheet and copy pasting all the required equipment names to itself is enough to re-write the link between equipment and schematic device. Best, george Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted April 2, 2023 Vectorworks, Inc Employee Share Posted April 2, 2023 Thanks for the update George! And for sharing this with the community! Quote Link to comment
