david p Posted October 26, 2005 Share Posted October 26, 2005 I have been having a problem with the Batt Insulation. I have a hard time selecting it after it is on the drawing. If I have to move it for some reason I can't select it! this has happen in New files on VW 11.5.1 Quote Link to comment
islandmon Posted October 26, 2005 Share Posted October 26, 2005 The 'Hard to select' issue comes up occassionally . Selection requires active handles but sometimes handles cannot be activated for some reason or other. A corruption in the file causes objects to become visible but unselectable ... more or less ... this is may be a result of class attribute issues. This being said ... what version of the Batt Insulation Plug-in are you using ? The "Batt Insulation.vso" with v11.5.1 was created Feb.3,2005 ... possibly you may be using an older version. Quote Link to comment
Travis Posted October 26, 2005 Share Posted October 26, 2005 Also, David, where are you using the PIO? On a Sheet layer (Viewport Annotations?) or on the Design Layer? If you're annotating a Viewport, you should check to make sure you have the insulation's Class turned on both at the Viewport and the general sheet Class Visibilities settings. Good luck, Quote Link to comment
