Sloader Posted March 14 Share Posted March 14 I have the script below which places, scales and rotates tree symbols based on a set of 2d Loci created in GIS. I would like to set the Z position of the symbols based on an attribute but can't get it to work. I am trying to use Move3D as below but no joy. def ReplaceRAND1s(h):#Function to replace all loci from imported shapefile with scaled canopy symbols rand=vs.GetRField(h, 'TreePointsForSymbolsRec','RAND_COLOU')#Get the random colour for the canopy loci sym= vs.Concat('Canopy-'+ rand)#Convert the colour code to canopy symbol name ScaleX=vs.GetRField(h, 'TreePointsForSymbolsRec','RAD')#Get scale from loci record ScaleY=vs.GetRField(h, 'TreePointsForSymbolsRec','RAD')#Get scale from loci record ScaleZ=vs.GetRField(h, 'TreePointsForSymbolsRec','rvalue_1')#Get tree height from loci record AOD=vs.GetRField(h, 'TreePointsForSymbolsRec','DTM_1')#Get AOD height from loci record X, Y = vs.GetLocPt(h)#Get location from loci to place symbol randrot= vs.Random()*100 #create a random number to rotate the symbol by vs.Symbol(sym, X, Y, randrot) # place symbol based on loci postion, random colour and random rotation vs.Move3D(0, 0, AOD) h2 = vs.LNewObj() # get handle to new symbol instance vs.SetObjectVariableInt(h2, 101, 3) #Set symbol scaling to asymetric vs.SetObjectVariableReal(h2, 102, ScaleX)#Set X scale vs.SetObjectVariableReal(h2, 103, ScaleY)#Set Y scale vs.SetObjectVariableReal(h2, 104, ScaleZ)#Set Z scale/ height vs.DelObject(h)#clean up loci vs.ForEachObject(ReplaceRAND1s, ("T=LOCUS")) #loop for all the loci in the file TreeLoci.vwx Quote Link to comment
MullinRJ Posted March 14 Share Posted March 14 (edited) Try using: vs.Move3DObj(vs.LNewObj(), 0, 0, AOD) instead. This moves the symbol by referencing its handle, and vs.LNewObj() returns a handle to the last object created in the drawing – "usually". Raymond PS - After actually reading your code, move the "move symbol" line after you assign variable h2. Then it should look like this: h2 = vs.LNewObj() vs.Move3DObj(h2, 0, 0, AOD) vs.SetObjectVariableInt(h2, 101, 3) #Set symbol scaling to assymetric ... Edited March 14 by MullinRJ 1 Quote Link to comment
Sloader Posted March 17 Author Share Posted March 17 Move3DObj does work, many thanks. I see its listed right by Move3D in the Function reference and I still didn't spot it. I also seem to be missing something about how to use the search tool in the procedures dialogue within VW. Quote Link to comment
