HebHeb Posted March 13, 2022 Share Posted March 13, 2022 Hello, I have some landscape area tools with plants attached/containing: problem #1: the plants (3D objects) are only visible when the active layer ist the one containing the landscape area problem #2: only the landscape area exports to my ifc file, the plants are missing. (note: got the plant tool (any everything else i use) mapped to my preferences - so a missing ifc assignment is not the problem) an unacceptable workaround would to "explode/convert to group" because I export my files on a regular basis and don't want to redo it before every export. any solution, anyone? Cheers Quote Link to comment
HebHeb Posted March 14, 2022 Author Share Posted March 14, 2022 (edited) it seems that the landscape area needs a "secundary" ifcEntity... I just had ifcSlope mapped primarily. But the #2 "problem" persits. EDIT: Solved by v2022 Service Pack 3 Edited March 25, 2022 by Heblon Quote Link to comment
DaxinWu Posted August 11, 2022 Share Posted August 11, 2022 (edited) On 3/14/2022 at 7:44 PM, Heblon said: it seems that the landscape area needs a "secundary" ifcEntity... I just had ifcSlope mapped primarily. But the #2 "problem" persits. EDIT: Solved by v2022 Service Pack 3 Hi Heblon, Does the 3D component of plants have to be real geometry? Or does IFC export work for image prop as well? I failed several times trying to export image prop plants as IFC files :( Edited August 11, 2022 by DaxinWu typo Quote Link to comment
Laura Stone Posted April 20, 2023 Share Posted April 20, 2023 This has broken, it worked in VW2022 Plants not exporting from exactly the same file in VW2023 Quote Link to comment
HebHeb Posted April 21, 2023 Author Share Posted April 21, 2023 yes, I have (still have) the same issue with SP4 2023 right now. Thing is: i have a custom ifc-mapping (class based via data-manager) so there might be some complex order of dataflow going on (wrong settings for the PIO plant?)... I somehow got the plant export working when reactivating the standard ifc4 settings, but unfortunately no solution for me. So I am really interested in ifc settings for LA and Plant. Quote Link to comment
Vectorworks, Inc Employee Katarina Ollikainen Posted April 23, 2023 Vectorworks, Inc Employee Share Posted April 23, 2023 @Laura Stone, I've checked with the latest build and the bug is fixed - this should be sorted with the next Service Pack. If you have something urgent you need to get out, please send it to me and I'll export it for you. 1 Quote Link to comment
Laura Stone Posted May 5, 2023 Share Posted May 5, 2023 Hi Katarina Thanks for that, I do have something I'd like to get out, so will send a drawing over Laura Quote Link to comment
Laura Stone Posted May 16, 2023 Share Posted May 16, 2023 Just downloaded the new service pack and all fixed - thanks very much! (image from solibri) 4 Quote Link to comment
