3d Poly contours Z heights changed when copied into new file??
HEengineering
I have a bunch of 3d poly contours all with Z heights around 700 feet. When I copy these into a new file then all seem to drop about 650 ft bc all my coutour z heights are in the 60's then? This happens if I even if I create the model in the original file. Its correct, and then when I copy into a new file same results.
This has to be some kind of file setting Im missing. Ive never encountered this before. Done this work flow about 200 times. What Am I missing?
4 answers to this question
