Rotate - why does a positive number rotate counter-clockwise and a negative number rotate clockwise?
yasin2ray
12 answers to this question
I think it’s the method that all CAD programs use. It’s to do with mathematics and the Polar coordinates system which always go counter-clockwise.
I am sure someone else will be able to elaborate with a more academic explanation but I accepted it long ago and have got used to it!
  • Like 3
24 minutes ago, Andy Broomell said:
Like Mark said it's based on Polar Coordinates, with 0° equating to the positive X axis. If you look at the 30° line in the graphic above you can start to see why positive values correlate to moving "counter-clockwise." It helps to picture this chart rather than a clock when thinking about rotation.
Hmm! Okay, thank you! I bet I haven't thought about that since high school.
It seems like mathematicians just being awkward by adopting a convention that is different from the one we all know from a compass.
but what if you are calculation angle of elevation from horizon?  Doesn’t the positive x axis being 0 degrees make perfect sense?  Putting it all into perspective, we need both azimuth and elevation conventions for angular measure 😉
Well, the horizon is a very slight curve, whereas a plumb line is straight. If we are calculating an angle relative to the horizon, what we are really calculating is angle relative to a line perpendicular to the direction of gravity/a plumb line.
Therefore I'm going to argue that taking vertical as our 0 degrees reference makes more sense - and it also corresponds with what most people are used to; compass directions.
Architects vs astronomers 🙂
19 minutes ago, FlyingHoward said:
For me, this "reversal" seemed to happen a SP or two ago where a Rotate 45 caused a Counter-Clockwise rotation.
This has always been the way things have worked in both Vectorworks and AutCAD. It is a CAD convention which is just one of those things. As I said above, it is something you just get used to over time and I rarely find it a problem anymore.
Here is the source of your pain!  https://en.wikipedia.org/wiki/Polar_coordinate_system
On 8/11/2022 at 4:27 PM, LarryO said:
Then I would ask why the menu icon representing the rotation tool shows the arrow in a clockwise direction?
That would imply that a positive entry would rotate the object clockwise. 🤷‍♂️🤣😂🤣
THIS. As well, the description of the Rotate Tool should say something about polar coordinate rotation.
