capital_Designs Posted March 8, 2022 Share Posted March 8, 2022 (edited) Is anyone else having this problem? I did a quick Forum search and turned up empty-handed. Starting from a new template file, which has several pre-made Label Legends in it, if I click to make sure one is set to "active" in the Label Legend Manager, when I go to place any light, the "active" legend isn't applied. The OIP "Use Legend:" dropdown shows that it's using a legend called "None". The options at the OIP dropdown are "<none>", "None", and the 3 standard legends in my startup file. I don't remember there being two options for none before... so that's making me suspicious. This is also happening for me when I open previously saved plots, in addition to the File...New (from template) test. It doesn't seem to matter which legend is "active" in the Label Legend Manager. Once I select any unit and in the OIP change the Use Legend dropdown to the desired legend, all is well. "Assign Legend to Lighting Devices" also works, so those are behaving as expected. Thanks in advance, Edited March 8, 2022 by capital_Designs Quote Link to comment
markdd Posted March 8, 2022 Share Posted March 8, 2022 I reported the bug a few weeks ago. Do you have an apple silicon machine as this is what seems to be the problem? 1 Quote Link to comment
capital_Designs Posted March 8, 2022 Author Share Posted March 8, 2022 Ah, gotcha. Thanks! Yes. MacBook Pro M1 Pro, Apple Silicon. Glad it's not just me! 1 Quote Link to comment
Charlie Winter Posted March 9, 2022 Share Posted March 9, 2022 Ditto. I've got the same issue. Should I submit a bug too? Quote Link to comment
Pelle Herfst Posted March 16, 2022 Share Posted March 16, 2022 Hi All, I seem to have the same issue as my active label legend does not work anymore and a class : Dimension is the active label legend, which is no label legend at all. This problem seems to be in Apple M1 machines only as my colleagues don't have it and I use a Apple M1 Max. Quote Link to comment
Peter Vandewalle Posted July 6, 2022 Share Posted July 6, 2022 Hi All, I'm now also running into this issue. On my old Intel Macbook the issue didn't exist. Since I swapped to an M1 Max, I'm now part of the club 😞 Quote Link to comment
