dennisp Posted February 16, 2006 Share Posted February 16, 2006 When in the 'SET DEFAULT PLANT TOOL OPTIONS', if I select a plant by scrolling through the symbols in the box above 'edit plant', a different symbol is placed than the one I chose.?? Quote Link to comment
Guest Posted February 16, 2006 Share Posted February 16, 2006 That should not be happening, could you go into a little more detail as to the specifics of how this is happening or what's causing this type of behavior? Quote Link to comment
dennisp Posted February 18, 2006 Author Share Posted February 18, 2006 I placed custom symbols in the 2d default library so I can access them through the Place Plant Tool. Some of these work fine, others do not. When in the Define Plant box some of the symbols are labeled 'Not valid'. Once I get past the first 'Not valid symbol' the mix up begins. I'll choose the symbol but the identifier above the symbol reads a different plant, and that plant is placed in the drawing. Quote Link to comment
