I have an office dimension standard setup with dual dimensions, primary is feet and inches, secondary is inches only. I don't often use angular dimension but needed it today and the displayed angle is showing both a primary and secondary angle. The object info palette doesn't have the field to switch to primary only. Interestingly when I select all dimensions including the angle dimension the object info doesn't have the primary / secondary view field. Deselect the angle dimension only and the primary / secondary view field is now available. I've switched the angled dimension to Arch standard to resolve the issue but is there anyway to correct this within my office dimension standard?
Mitchell (the other one)
1 answer to this question
