DomC Posted February 27, 2022 Share Posted February 27, 2022 Hello Would be great if anybody could help me. At the end result I want to be able to exchange a popup's choices. What I am trying to do is, that I delete the items with vs.RemoveChoice() and build it new with a loop through my choices. I think I make something wrong by indexing with "AddChoice" or "RemoveChoice" just remove the string not shorten the Choice Numbers. My script: choices1 = ['choice1', 'choice2', 'choice3', 'choice4'] choices2 = ['choiceA', 'choiceB'] def CreateMyDialog(): vs.dialogid = vs.CreateLayout('Dialog Name', 0, 'OK', 'Cancel') dialogID = vs.dialogid vs.CreateStaticText(dialogID, 10, 'Popup', 60 ) vs.CreatePullDownMenu(dialogID, 11, 40) vs.CreateCheckBox(dialogID, 12, 'Change Popup') vs.SetFirstLayoutItem(dialogID, 10) vs.SetBelowItem(dialogID, 10, 11, 0, 1) vs.SetBelowItem(dialogID, 11, 12, 0, 1) return vs.RunLayoutDialogN(dialogID, Dialog_Handler, 0) def Dialog_Handler(item, data): dialogID = vs.dialogid if item == 12255: # enter Dialog 12255 -> 12256 exit dialog for i in range(len(choices1)): vs.AddChoice(dialogID, 11, choices1[i], i) if item == 12: #checkbox if data: #checkbox True num_choices = vs.GetChoiceCount(dialogID, 11) for i in range(num_choices): vs.RemoveChoice(dialogID, 11, i) for i in range(len(choices2)): vs.AddChoice(dialogID, 11, choices2[i], i) if not data: #checkbox False num_choices = vs.GetChoiceCount(dialogID, 11) for i in range(num_choices): vs.RemoveChoice(dialogID, 11, i) for i in range(len(choices1)): vs.AddChoice(dialogID, 11, choices1[i], i) result = CreateMyDialog() Quote Link to comment
DomC Posted February 27, 2022 Author Share Posted February 27, 2022 edit: Found something in the Forum here. I will try to check this. Quote Link to comment
DomC Posted February 27, 2022 Author Share Posted February 27, 2022 (edited) Hello Solved by searching the Forum. Seems we need backward indexing to delete the choices. Here the working popup Dialog. choices1 = ['choice1', 'choice2', 'choice3', 'choice4'] choices2 = ['choiceA', 'choiceB'] def CreateMyDialog(): vs.dialogid = vs.CreateLayout('Dialog Name', 0, 'OK', 'Cancel') dialogID = vs.dialogid vs.CreateStaticText(dialogID, 10, 'Popup', 60 ) vs.CreatePullDownMenu(dialogID, 11, 40) vs.CreateCheckBox(dialogID, 12, 'Change Popup') vs.SetFirstLayoutItem(dialogID, 10) vs.SetBelowItem(dialogID, 10, 11, 0, 1) vs.SetBelowItem(dialogID, 11, 12, 0, 1) return vs.RunLayoutDialogN(dialogID, Dialog_Handler, 0) def Dialog_Handler(item, data): dialogID = vs.dialogid if item == 12255: # enter Dialog 12255 -> 12256 exit dialog for i in range(len(choices1)): vs.AddChoice(dialogID, 11, choices1[i], i) if item == 12: #checkbox num_choices = vs.GetChoiceCount(dialogID, 11) for i in range(num_choices, -1, -1): vs.RemoveChoice(dialogID, 11, i) if data: #checkbox True for i in range(len(choices2)): vs.AddChoice(dialogID, 11, choices2[i], i) if not data: #checkbox False for i in range(len(choices1)): vs.AddChoice(dialogID, 11, choices1[i], i) result = CreateMyDialog() Edited February 27, 2022 by DomC 1 Quote Link to comment
