Tom W. Posted February 23 Share Posted February 23 I think you would need to create this using two Windows, using an inner (or is it outer?) window to represent the blinds: set it to 'Fixed Light - No Sash' + with 'Replace glazing with louvers for Sash' enabled. Choose Jalousie louvers + adjust settings to get the blades looking the way you want. You won't be able to raise + lower the blinds but could have open + shut (or half-open) versions that you make visible/invisible by class to show different states. Don't think there are additional options with WinDoor but someone else may know better Quote Link to comment
Tom W. Posted February 23 Share Posted February 23 Or you could try using an Overhead Door for the shutters Quote Link to comment
